I have a couple of oil related problems with my Yamaha 200 from -84.
The remote tank pump won?t stop filling up the main tank. As soon as I turn the key, the remote tank pump will start filling up the engine tank and it doesn?t matter if the main tank is full or not, it will continue to pump until the main tank is flooded.
I removed the level sensor from the main tank and moved the float switch by hand to the upper position, but the remote pump keeps pumping oil anyway.
Another strange thing is that the alarm only starts when the float switch is half way down, approx where the remote tank pump should start pumping oil to the main tank. When moving the switch all the way down to the bottom, the alarm stops.
I connected another main tank level sensor from my Yamaha 115, but that didn?t make any difference. I also change the oil control module, but no difference.
Last but not least, the oil level sensor in the remote tank is also giving me a hard time.
It doesn?t matter if the float switch is moved all the way down or all the way up, the green lamp on the oil level gauge is lightened all the time.
And even if the float switch is moved by hand to the bottom, the remote tank pump will start pumping oil as soon as I turn the key. It shouldn?t do so when the level sensor tells the oil control module that the remote tank is almost empty.
I bought the engine this spring and the previous owner had disconnected the whole oil pump system, so maybe it?s some sort of wiring problem?
Maybe Rodbolt can come up with something?
