So...I think I'm going to give up on my old Evinrude 90hp. It's starting to cause trouble, one thing after another. First it was the fuel pump, then a thermostat stuck and burned up a head gasket, a couple hours later, the stator fails.
I think I'm going to bit the bullet and go for a new engine. They're a lot easier on gas than the old v4, and I need reliability where I'm headed. I think I'm going to stay in the 90 hp range, my boat performed pretty well when the engine was working right. ~39 mph empty with 2 guys and a couple cans of gas, ~35mph with all the gear and 4 people.
The boat is ahhh.....one of a kind I guess????? I built it from scratch last spring. Rather than try to explain the style of boat I'll just add a pic, lol. I will tell you that it is 18.5 feet long and is pretty heavy for it's size. There is no shortage of fiberglass in this one, there are places the fiberglass is a full 1.25" thick! There isn't a powerful enough outboard around that I'd have to worry about putting on the transom, lol, weight would be my only concern.
The question is, which 90hp engine would you buy today? All of the dealers are between 30-60 minutes away, so that doesn't really make much difference. Service would probably be about the same at all except evinrude, they might be a little better.
Don't just come out and say "I'd pick "x"". Try to give me a reason why you would pick "x".
I'm kind of leaning toward the etec, but what would you buy?
