Slice of Life
- Apr 2, 2013
- 78
For the past two seasons my 92 Bayliner with Alpha one gen II has had a very minor water leak where the control arm comes out connecting to the upper swivel shaft. I?ve read up on the upper swivel shaft corrosion/seal with sloppy steering issue. I considered taking on the JR Marine drill procedure to replace the shaft and repair/replace the gimbal ring, but have put it off. I replaced the bellows myself two seasons ago and feel confident in this job, preparing for the headache ahead of time. I don't feel safe taking it out this season until it gets fixed/replaced due to the loss of steering possibility I'm reading about.
I'm reading that if one has a water leak in the area, that it's a guarantee that the shaft and seal need replaced, and also that the gimbal ring needs replaced or rebuilt at the least. One of the things I'm unsure on are the modified wrenches required. Watching JR Marine's YouTube video you see him using wrenches that are modified. Their vendor that they sell their cover plate kit from also sells the wrenches for $100, seems a bit steep. Possible without them? The swivel shaft itself varies from $75 to $300. I don't plan on having this boat for another 20 years so if an aftermarket part erodes in half that time so be it.
Is it a safe assumption that the gimbal ring needs reconditioned or replaced because of this, or do some get by with just changing the shaft and seal? I haven?t actually tested to see how far the outdrive will move before the steering wheel moves. It will move fairly easily from side to side by pushing it, but it will not move up and down any at all. Boat is exclusively in fresh water only.
Suggestions? Thanks.
