The model number is 502ACPMDA. I've taken the boat out three more times and the low idle will hang in there for about 30 seconds now before it dies.
It appears that your engine could have either a 2bbl or 4 bbl Holley carburetor (if it is unmodified in the last 21 years)
You can view parts diagrams and numbers at
http://epc.brp.com/
- 3854107 Volvo Penta
- 18-7245 Sierra Marine
- 9-37630 Mallory Marine
iBoats actually sells Sierra parts at competitive prices. (and you can also get Sierra at NAPA)
Before you jump right in and start tearing your carburetor apart though you should probably ensure that you have good fresh fuel in the tank, new fuel filters and good clean sparkplugs, dist cap and wires.
Since your engine and drive are essentially a Volvo SX, all the part numbers are Volvo (beginning with a "3") you can get them from your favorite Volvo Penta dealer but be ready for some sticker shock
If it's a 2-bbl, you can order the carb repair kit right here!
http://www.iboats.com/Carburetor-Kit-18-7244-Sierra/dm/view_id.172041
4-bbl
http://www.iboats.com/Carburetor-Kit-18-7245-Sierra/dm/view_id.172042
Before you rebuild the carb though, you should probably try adjusting it along with the throttle/carb cable. There's a rather specific procedure to do it.
It's not hard and it really would help to have an OEM service manual. (NOT Seloc/Clymer although they're pretty good for starting your woodstove)
You can also go here:
http://boatinfo.no/lib/omc/manuals/1986-1998omcmanual.html#/0 but you need a fast internet connection and a BIG display!
Regards,
Rick
