It is a Mastercraft. I have filed a claim with my insurance and an appointment with the Mastercraft service center in Portland to get the boat thoroughly inspected. Thanks for the help and answers to my question.
Howdy,
Welcome aboard!
Did a little searching for a 1992 Mastercraft 190 Prostar and found a couple for around $6000-6500
It's very possible that the insurance company will "total" the boat (and possibly only give you some percentage of replacement value etc)
Once water gets under the floor, it's nearly impossible to remove it before it totally rots out all the wood underneath. The only practical "fix" is to remove (cut out) the floor and expose the stringers below to completely dry them out.
Not at all impossible at all to do a floor replacement of any boat, but in many cases, (unless you do the entire job using free labor) it's just not worth it.
All of this in addition to the probable engine and transmission rebuild/replacement which will only further add to the total cost (and will be much higher than the boat will be worth after fixing it)
If you have insurance that will cover something like this, take the money and RUN!
Sorry about that,
Rick
Note to MODS, maybe this thread might be better moved to Boat Restoration, Building, and Hull Repair
