None. The 15 hp OMCs are already maxed out. Within some families of motors, .ie motors that share the majority of parts, stroke, bore, etc. there is usually one that is maxed, with one ore two other detuned versions that use smaller carbs, but adding a larger carb to the top model won't do anything but make it run like crap. Too much fuel is just as bad as too little.
How much of an increase can you make on a 15hp two cycle motor by upgrading the carburetor? Can you go from a 15hp to a 40hp? I would like to understand what specs must be compared and how/where to get those specs before trying to make a conversion.
Can you upgrade en Evinrude 9.5hp? Can it be upgraded to 25HP or greater?
Yes you can upgrade a 9.5 to 25 hp it is easier than most people think. This is the procedure
#1 Put ad to sell 9.5 on craigs list.
#2 wait for sucker with cash.
#3 sell to sucker with cash
#4 Put money from 9.5 in your wallet.
#6 Look on craigslist for 25 hp motor.
#7 find 25 hp you like.
#8 take cash from 9.5 plus extra out of your wallet.
#9 give cash to seller.
#10 take 25 hp motor home.
There you go 10 easy steps to turn a 9.5 into a 25 hp motor for mostly free.
