Celebrity 240
- Sep 12, 2018
- 6
1995 Mercruiser 7.4 was running fine and then suddenly shut off. After cooling off it would go for awhile and quit again. Did this several times on the way home. The coil would get very hot so I diagnosed it as being a bad coil. Put a new coil on and it ran for a few short outings and I assumed it was fine. Took a trip and got about 40 miles from home and it shut off again. Coil was blistering hot again. After several pit stops for it to cool made it back home and started looking for the real problem.
The only thing I can find is the voltage at the positive side of the coil is erratic, With key on I have 12.5 volts at the battery and at the coil. Start the motor and battery goes to 14.6 but voltage at the coil is all over the place from as high as 14.6 and down to 1.5 and everywhere in between.
Unhooked purple wire from coil and ran a jumper from battery to coil. With motor running I get a steady 14.6 volts to the unhooked purple wire but the coil running off of the jumper is still all over the map. I figure this unstable voltage is causing the coil to overheat and breakdown and then go again after it cools.
Checked all the grounds and found nothing. Any ideas what could be causing the unstable voltage. Sorry so long but I wanted to try to explain everything. Thanks in advance.
