dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
I was taking apart an old 1984 4.3 v6 Mercruiser. The crankshaft has a different flywheel and coupler connection, instead of a triangle and mounting bolts, old coupler goes on a set of studs and tightens with the nuts. Could I use this coupler and flywheel on the newer 1993 engine with the chevy block rebuilt for marine application? Thx. Also, how different is a triangle coupler and could it be used with the gen one alpha one outdrive shaft?
