10320 LUCAS GREASE 14oz TUBE
0  Saves
Brand
Dexter Marine Products
$17.54
Out of stock
SKU
IB1235737
Mfg
11008
Ships: In 1 Business Day
Need Help? Call 1-800-869-1686
Lucas Marine Grease is a premium, heavy-duty lithium complex NLGI GC-LB certified grease formulated with a unique additive system designed to provide maximum lubrication under the most severe marine operating conditions. It is a true marine grease with applications in trailer wheel bearing, trailer chassis lubrication, automotive wheel bearings and outboards. It has a typical weld point of 620 Kg (the minimum industry standard is 200 Kg). It is not recommended for centralized dispensing systems. NLGI GC-LB certified, Typical weld point of 620 Kg the minimum industry standard is 200 Kg, Timken load of 80 lbs., Dropping point of 540 lbs., Provides rust and corrosion protection in both fresh water and salt water environments, Effective water-resistance, Long-lasting, Resist extreme pressure, & Extreme friction reducer.
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
California Prop 65 WarningWARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
Write Your Own Review
Only registered users can write reviews. Please Sign in or create an account
Copyright © 2024 BOATING INVESTMENT GROUP LLC., - IBOATS. All rights reserved.
