Raritan 1700 Series Electric Water Heater with Heat Exchnager: 6 Gallon, 120v
0  Saves
Brand
Raritan
$1,387.17
Out of stock
SKU
IB00189836
Mfg
170611
UPC
085462001499
Ships: In 1 Business Day
Need Help? Call 1-800-869-1686
1700 Series Water Heater
120v
6 Gallon
With Engine Heat Exchanger
The "1700 Series" water heater provides hot water for galley and shower. Dense foam insulation provides better and longer heat retention than traditional fiberglass. The tank itself is protected by a 75 PSI T& P ( temperature and pressure) relief valve. The cylindrical design of the tank enables it to withstand more pressure than a cube shaped tank.
Heat exchanger models can be connected to the engine cooling system. This provides the added convenience of hot water when underway or generator power is not available. The innovative heat exchanger is over seven feet in length and is evenly coiled throughout the interior of the tank, providing hot water rapidly and efficiently.
Raritan's water heaters use an ignition protected thermostat. Although it is factory set to 120°F, it is adjustable from 110° to 160°F and has a safety shut down limit of 190°F. All models and sizes have the plumbing connections on the same side to simplify installation. Hot and cold water connections are 3/4" male NPT (National Pipe Thread). Heat exchanger connections are 3/4" female NPT.
Benefits:
  • Simple installation - retrofits to most on-board pressure systems
  • Proven long-life design
  • Withstands the rigors of the marine environment
  • Glass-lined steel tank is more durable than stainless steel
  • Attractive polymer jacket resists corrosion from dampness
  • Ignition-protected, adjustable thermostat
  • Round tanks are designed to withstand more pressure than square tanks
  • Glass-lined steel tank for long life and high efficiency
  • Environmentally friendly CFC-free foam insulation
  • Replaceable magnesium anode to protect tank and neutralize acids in the water
  • The tank is covered by a five-year Limited Warranty
  • Each unit is assembled by hand, individually tested and backed by Raritan's two-year Limited Warranty and legendary technical support team
Please be aware that all products have a production or warehouse lead time. This is the number of business days (typically not including the day the product was ordered) that must pass before the item begins the shipping process. Please see the "Ships: In" information located within the main product description to the right of the product image and below the ADD TO CART button for that particular product's "Ships: In" timeframe.
IMPORTANT: Please note that these timeframes are estimates only based on the latest information provided to us by the manufacturer/supplier. Delays in both material, production and shipping timeframes by manufacturers can vary without advanced notice and while we do our best to keep "Ships: In" timeframes up to date we may not always be able to do so due to a variety of factors.
If a product is needed by a specific date we strongly recommend you reach out to our Sales team (1-800-869-1686) to verify shipping timeframes.
Canadian orders please add an additional 14 business days for processing and shipping. Alaska and Hawaii orders please add 1 additional warehouse processing day.
Click here to see our Standard Shipping Policy
California Prop 65 WarningWARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov.
Write Your Own Review
Only registered users can write reviews. Please Sign in or create an account
Copyright © 2023 BOATING INVESTMENT GROUP LLC., - IBOATS. All rights reserved.
