Goochsplat
- May 30, 2015
- 12
I have a alpha 1 Gen 1 outdrive. I have taking it off and split the two and changed the impeller. I then made sure the lower was locked in forward and reassembled to the upper. I re-greased the u-joints and splines and such. It was in forward gear to remove and came out easy. The shoe was straight and put new gaskets on and put the drive in no problem which I have done this procedure 20 times before with no problems. When I tried to put it in reverse it won't go. I took it off again and made sure Everything looked ok and tried the shifter on the console and it worked fine without the drive installed. I tried shifting the outdrive manually inside the lower and when it was put together and it was all fine. It was working fine before I did anything. Very frustrating..... Any ideas please???
Thanks scott
Thanks scott
