1961 QD 22 10HP
Thebone
I have it running but it has a lot of grayish milky stuff running out of the drain holes at the bottom of where the lower unit go together is it not burning all the fuel?
fhhuber
Going to need pictures but that sounds like oil-water emulsion which is not good.
Quick check... do a lower end oil change and see what that oil looks like.
flyingscott
Sounds normal especially if you are running 24-1 like it needs. The motors rarely get warm enough in a tank to complete the burning process so that goo is just a by product absolutely normal. If the lower unit lube is clear of water good to go. Take it out on the lake and run it get her nice and warm and you won't see that.
flyingscott
That motor runs 24-1. they did not change to 50-1 until after 63/64. The emulsion is still normal with a 50-1 mixture.
Thebone
Ok thanks just talk to the guy that did my lower unit he said it is unburned fuel or fuel pump may have him look at it just trying to keep from pour money in it thanks again
flyingscott
Take it on the lake A lot of people have the same question on this forum. Always the same answer normal run it till it gets warm on the lake. Fuel pump problems will also show up on the lake usually not in the barrel.
oldboat1
If it's running, it may be running cold (above note). If it's not firing, check the spark (spark tester). It may be that you haven't got the air/fuel mix quite right, and need to dial it in.
oldboat1
Thanks. The surface temp at the top of the head should be about 130-140F -- warm to touch, but not hot enough to burn after touching for a few seconds. (Running cold can give poor combustion.) It sound like it's getting up to temp, offhand. On the other hand, temp at the top of the head shouldn't exceed 160.
Additionally, you may be running rich due to a rich air/fuel mix. The top (l.s.) needle should be about one turn open, maybe a little more. The bottom needle (h.s.) should be about 3/4 open. Lean is clockwise, and the object is to get it running well at a lean setting (best combustion).
flyingscott
Then it was normal Any time you run it in a tub you will get that. I would check the thermostat though just to make sure it's working good not crusted up or stuck open like racer said and change your fuel mix to 24-1
Thebone
Sorry I have so many Questions but trying to get new plugs 2 of the auto parts store sold me plug the are suppose to match but the NGK'so are almost 1/4in longer and Access ACDelco'so look way to small I have just seen in walmart a L77jc that look just like the J4C'so has any one seen them
Thebone
Asking about plus because I have cleaned the old one they where black put them back in just this morning started on first pull answer Idle down more with out cutting off
Sorry , but J4C is the correct plug.----Should be easy to find.-----Do not try those that " look the same " to you.
