saltchuckmatt
- Jul 19, 2019
- 3,208
Hey everyone,
Helping my neighbor with his 1977 evinrude 35 horse. Fixed most stuff and cleaned up some stuff someone else messed up. Running good. Removed the bolts and nut that hold the gear case on so I could pull it and change out the water pump. Anyone know where to undo the shift shaft on that motor. I have a 1985 30 hp and you access it through the water pickup screen. This one is not that way. I can see the connector in the parts breakdown but not where to access it. The only thing I can guess is there is an exhaust port cover near that area but the two screws don't want to come out...at least easily. There is nothing under the carb. Model number is 35702h
Any help would be greatly appreciated.
Matt
Matt
