South Paw
- Apr 10, 2012
- 52
Question 1982 Johnson 70hp no spark no tilt/trim
Firstly let me say hello, I've been a long time lurker now first time poster and I can honestly say I've spent hour upon hour sifting through all the relevant threads lol.
A few weeks ago i launched my boat, she fired 2nd go as usual, i went to park the car and trailer and upon return my wife informed me the engine had stalled. OK I thought, well after 15 minutes of cranking with no luck i had to give up and clear the boat out of the way to make room for others, this is when i noticed the tilt/trim was also no longer functioning. Could this be pure coincidence?
After a couple of hours of messing about removing plugs and checking and cleaning and really i'm at a loss as to what helped but i had tilt and trim again but still no spark.
I took the advice of a friend who did a simple spark test and concluded it was the power pack. Shame on me for that as i have just waited two weeks for delivery of a new one to Australia and lo and behold still no luck and after raising and lowering the engine a few times today the t/t quit again
The old Johnno was running great prior to that fateful day.
Things I've done. I have replaced the power pack with a new OMC one. I have replaced the rectifier. I have checked that fuel is not the issue. I did a spark test using known working spark plugs and also new ones.
Here's a bit of info that may or may not mean much but with the fast idle lever up she will fire/run for a few seconds then die and a timing light has shown intermittent spark when it does this.
I now have a local guy telling me that his diagnosis is to replace the stator and timer base ($400). Now could they just fail suddenly? Could i have gotten a faulty power pack? Could an intermittent issue with the ignition switch or kill switch also affect the tilt/trim?
I can hear the relays clicking and I'd like to check the junction box bolted to the inside of the transom but looks like I have to bust the lid to see because the screw driver slots are too corroded and i cannot get a socket on them, is there anything in there such as a fuse that could be giving me grief? Oh i have also checked all fuses around the engine, cleaned all grounds i could find, battery has no trouble cranking either.
Could i try disconnecting the large red plug under the cowling and jump the engine as i have read in other threads. Can someone explain to me exactly how i do this as i don't want to blow anything or damage the threads with arching.
Sorry for the long post i just wanted to be as clear as i could. Thankyou for all and any help.
Just thought i would add this, i had the battery tested today, 12.98 volts, it was fully charged and 714 cca battery is rated at 650 cca.
Can i add, I have found it bloody frustrating when someone starts a thread and never comes back to let folks know how they went, good or bad, fixed or not lol
Wishing Joe Reeves lift on my street.
