1986 OMC 5.7 L Need service literature - SOLVED
joey nathan
Carbureted engine 57 4APKW / Serial # T0908833 with Cobra Stern Drive -
Specifically looking for canister fuel filter P/N
Thanks...
joey nathan
Thanks Lou, but no fuel system stuff there, only carburetor...Still stumped by this QuickSilver part Number 802462Q fuel filter / separator - resembles spin-on oil filter...
joey nathan
QuickSilver Fuel Filter - Need Help
Slash Water Separator - cannot find a cross for 802462Q this spin-on filter
joey nathan
OMG No wonder - I transposed a couple numbers here Correct number is 802426Q and I've found it now...Thanks anyway!
Ayuh,... You've sure got Me confused,....
Quicksilver is Mercruiser aftermarket parts,....
Mercruiser fuel filters won't fit an OMC filter housin,... Different threads,....
'n this thread is in the OMC forum,....
Lou C
http://www.crowleymarine.com/johnson...cfm?mdl=N0QEGQ
Its part # 51....but this page of the catalog got messed up, the part is not listed correctly, the original # from my literature is 502905 and in the aftermarket (Sierra) the one you want is 18-7946
​PS the number you have may be an outdrive number, it is not an engine model # which is what you need to get the right parts.
​it will start with a 57 (5.7 liter) and have a 4B next (4bbl carb) then a P (if power steering) or M (if manual steering, unlikely) then there will be 4 more letters, not sure what differences they signify....
your model # (usually its on a label on the valve cover, or thermo housing) and then you can look up parts.
​for this part it doesn't matter though, they are all the same for the V8 and V6 models of that vintage...
OE# OMC0502905
Sierra aftermarket:
18-7946 10 micron or
18-7846​ 21 micron
​this site won't let me link directly to the BRP catalog website, but that's the best source of information for parts questions.
GA_Boater
Changed the thread title by adding solved. Also merged both threads you started on this because two threads causes confusion as evidenced by some of the replies.
