I'm new to boating, all around. Just picked up for cheap a 1986 SeaSwirl Spirit with OMC (what I believe to be) 800 Stringer (propulsion assembly #302STHRCOM)
[3.0L I4 - GM, I *think*]
The lower gear case had water in it, which froze over winter & cracked the case.
I've found a used, lower case on eBay, to bolt on as a replacement, to cruise around this summer.
Upon removal of my old lower case, though, I found some pretty FUBAR ball gears (on both the upper gear case & the intermediate housing)
They look *very* worn out (I can post some pics in the next day or so - I forgot to take them today; hands were covered in grease & dirt)
Couple of things I'm shopping ideas & opinions on, here...
1) [When pics are up] - will these ball gears get me through the summer, that I can R&R later this year? Or, if by running them, am I risking causing MAJOR damage? (I believe I've read that the drive should always be lowered completely before starting the engine or engaging the drive, correct?)
2) Are the ball gears easy to R&R, myself (I have an aviation maintenance, motorcycle, and car repair background, but I do not have a wide array of tools right now; pretty basic setup of wrenches & sockets, punches)
3) Is it worth the roughly $3,000 to have the www.sterndrive.info folks overhaul the whole thing, or is there another (Merc Alpha?) stern drive that could be installed in place of the OMC (I know linkages would have to replaced, and all that) - something with more available / current support?
Turning a $500 purchase into a $5,000 investment, quickly haha
Thank you, kindly (sorry if I happen to have re-posted from an old thread; I couldn't find anything specifically pertaining to this in the search, but I admittedly didn't look too long)
Cheers!
Cheers!
