1992 (ish) Evinrude 25 HP Remote Control Repair/Replacement
tpenfield
I was going to place this thread in the 'Steering & Controls' forum, but thought the Evinrude/Johnson forum might get a bit more traction. :unsure:
Anyway. My 13 foot Boston Whaler with 25 HP Evinrude OB (short shaft) is in need of some control box refurbishment or replacement. I'd like to either get some replacement parts or perhaps a new control box all together. (I don't have the Model # of the engine, but am fairly sure it is a 1992 model)
My challenge is that I am not much of an expert when it comes to outboard motor remote controls. Here are some pictures I grabbed off the web of what the control box looks like (it is side mounted, has ignition key, and the red/round connector to the engine.
I'd like to see if there are some part number listings for the controls of that era, but have yet to find anything. I did find one part # reference ( 432716, and/or 175945 )
I can buy some used and even a NOS control boxes that looks like the one I have. The cables are OK, probably just need some TLC, but wanted to make sure I know (better) of what I'd be buying.
I am also wondering if there are any new(er) remote controls (BRP branded) that would retrofit to the 1992 connector and the cables? :unsure:
Anyway, thanks in advance for any guidance on sourcing a replacement (or repair kit) either used or 'compatible' new. :D (y)
tpenfield
Any control box ( Johnson / Evinrude ) with the big red plug will work.
Thank you. Is there any chance that a new BRP control box would work if there are adaptors for the round vs. square plugs? or are there complexities to consider?
I believe there should be lots , lots of good used control boxes available.----But if beer tokens are not an issue then a new box and adapter cables is the easy way to do this.
saltchuckmatt
