I have an 89 Evinrude 150XP that the end of last year fried an ignition switch that was less than a year old. It had rained that day and assumed water had gotten into it. Replaced it and took it out another 1 maybe 2 times and all seemed good. I didn't have a chance to take the boat out until today this year and everything ran good for the first 8 miles or so multiple stops fishing and then I noticed some smoke I feared it might have been the ignition switch so I grabbed it under the console and was given a massive shock to the hand. I immediately turned the boat around and killed the ignition. The engine wouldn't start back up and acted like it wasn't getting enough power to try to crank. After some troubleshooting I found that the ground cable wire had come mostly lose After tightening the bolt it cranked normal and fired right up but after 15 seconds the ignition switch smoked some more and completely fried not working at all. Had to have another boater tow us back.
Would a loose ground wire cause the switch to fry? Should there be that much current running to the switch to shock me? Switch that was installed was a Sierra MP41000 I'm assuming they should all be the same.
