2 stroke crank case sealer?
samsims
What sealer do I used to seal the halves of the crank case?<br /><br />Thanks<br />Stacy
rodbolt
Re: 2 stroke crank case sealer?
what are we trying to seal?
Ray Neudecker
Locktite 518 is one of the most common sealers used to seal when assembling the two crankcase halves. I have used several things at a race when this has happened including (Devcon if time to cure is posible )or silicone if time is short. They are only temporary solutions. Disassembly and redoing the sealing are the long term way to go.
samsims
rodbolt-<br /><br />Motor is a '91 yamaha 200. There is no gasket between the crank halves. Yamaha says to use the gasket maker (I assume is some really expensive yamaha goop), which to me says rtv, but rtv should not be used in contact with gasoline.
rodbolt
to paraphrase a pink floyd lyric, ah haaaa how right you are.<br /> use the gasket maker,518,gel-seal II , any anerobic sealant in the same family. do NOT use silly cone<br /> you will regret it.<br /> good luck and keep posting
vinney
As the Who say's Don' get fooled again. GEL SEAL only. Make sure You lightly sand the two half with 1000 grit paper and brake clean the sufaces. The sufaces must be clean of any oil and old gel seal. No Silly Cone.
