jeremybethune
- Jun 22, 2020
- 9
motor is an 02 but new long block installed 2 years ago. Motor has 50 hrs overall =. Replaced fuel pumps, filter, injectors, throttle pos sensor and still wont run worth a crap. distributor and plug wires are most likly original ones. it idles great then when you put it in gear and start to give more throttle it starts to die or backfire thru intake. if you slowly ease the throttle it will rev up to about 2900rpm then shut off or sputter. when you pull back to neutral it will continue to idle then die when you put in gear. serial number on engine is 4202032980
