Hello,
So I am looking for some ideas on what else to check. I picked up a 2003 Stingray that has a Volvo Penta 3.0 GSP I/O with a SX-M in it and I’ve been doing all the work myself. Originally I would even be able to get this motor above 1600 RPM but after discovering it was a cracked head cylinder I replaced it and now I am able to get it up to about 25 MPH. The manual online says this thing should be able to get to 40ish at full throttle any ideas would be greatly appreciated. I’ll post all work below I’ve done. I believe the max RPMs under load is about 3500ish.
Plugs
Cables
Distributer Cap
Water Pump
Rebuilt Carb
Starter
Throttle Cable
head cylinder (175 On all 4 cylinders)
adjusted timing to 8 degrees BTDC (Manual says 2 ATDC but most forums say the smooth spot is 8 BTDC)
Power Steering Fluid gear
Exhaust rubber boot.
Belt
Fuel Filter
Fuel water separator
oil / oil filter
4 blade prop
Lower gear unit change with new seals
Yes, I know I’ve changed pretty much everything but this thing was a bit neglected and every but the motor was in great shape. Any ideas would be greatly appreciated once again. I’m kinda lost now.
Thanks!
Plugs
Cables
Distributer Cap
Water Pump
Rebuilt Carb
Starter
Throttle Cable
Belt
Fuel Filter
oil / oil filter
4 blade prop
Thanks!
