2007 mercruiser 3.0 Rust by the looks of it on side of block cover
Andrewvw
Hey while I was changing my starter out I noticed it doesn’t look very great I’m not to familiar with these small boat motors, if any one could give me their opinion o. This picture that would be appreciated.
Thanks
Andrew
alldodge
Welcome
I don't see an issue, looks like a bit of surface rust
Andrewvw
Thanks for the fast reply, one other thing I am missing a hose that comes off my valve cover which sprays oil all over, I’ve been trying to figure out where it’s suppose to run to. Not sure if that would be considered a vacume leak and causing it to idle rough?
alldodge
Could use your motor serial number to make sure
That hose normally gets connected to under the flame arrestor or right next to it. The motor sucks in air and the oil vapors get sucked in and burned.
Looking at your flame arrestor it looks like it needs to be cleaned, it's looks black
If you motor has a lot of blow by then the oil vapors can be excessive
airshot
Any leaks in that area when it is running? Grab a flashlight and look carefully for any signs of water leaks. My 1983 3.0 doesn't have any rust like that.....salt water use ??
Andrewvw
I’ve got it winterized until spring Ill have to wait until it warms up to fire it up and pull the oil cap, but here is the serial number.
Andrewvw
Hey As far as I know it’s only been in fresh for the last 10 years my dad owned it roughly 6 years and now I’ve had it about 4. Would be nice if they would of put a hour clock on them back in the day
alldodge
Good, your SN is 0W607592
The hose would go from the valve cover fitting to a tang on the flame arrestor. Can see in pic of the like, the hose just slide over the tang and then motor sucks in the vapors when it's running
https://www.mercruiserparts.com/863200-arrestor-flame
Scott06
Thanks
Andrew
just surface rust I had some in similar locations on my 3.0 that was fresh water only. Nothing to worry over. AD has you steered straight on the valve cover vent hose to flame arrestor. Some oil is normal on these. Mine always left a little sheen but ran hard for many years before I sold it, 25 years…
If the rust bothers you. Hit it with a rattle can of black engine paint
If the rust really bothers you, pull the starter, pull the dizzy, hit the rust with a wire brush. Then hit it with a rattle can of engine paint. Don't forget the timing cover that never had paint on it from the factory
Andrewvw
thanks for all the help I was trying to get my head around how the block has a cover you could pull off? Would that be for the cooling to run through the block? Maybe the gasket is wearing out that’s my guess. I’ve used this boat 10 times in 4 years and it’s only let me down twice lol, finally have time to figure out all its issues
Scott06
That side cover is for the lifters and pushrods. Wire brush and paint but sitting under a cover can get condensation in there. there is not a casket leaking there, they don’t spend a lot of time painting them. If it makes you feel better run it on the muffs and look for water leaking.
use it more… the 3.0 is a tough engine simple and robust.
It's the lifter cover.
Remember, the 3.0 is a stroked version of the 153 cubic inch 4-cylinder that was designed in the late 50s for debut in the 1962 Chevy II
Andrewvw
And cheap on fuel!
airshot
My 1983 3.0 was totally painted from the factory, just looking at his side covers, they appear to have streaks from a leak running down them.
