roger3645
- Aug 30, 2005
- 271
I'm running a 1983 Ranger 350 V, it is powered by a 1988 mercury 115hp with a 13 3/8 X 19 Ballistic prop. The boat is 17? 10? with a 6? 10? beam and a dry hull weight of 1050 lbs. By GPS I?m toping out at about 46 mph @ 5900 rpms. According to the tach it?ll reach 5200 rpms with the motor still trimmed all the way down. I tried a 13 X 21 aluminum (Mich Wheel) and could only hit about 35 mph before exceeding 5500 rpm. Should I try another prop if so what size do you recommend or is the mph about right for the setup and tach just off a bit?? Thanks
