I have a 88 5.7 260 HP mercruiser that cuts out at high RPM. When I attempt WOT and use the trim it seems to cut the engine out, almost as if it's robbing power from the ignition system. I checked the connections on the trim pump, all tight, battery's new, 14 volts on the gauge when under way. The trim works fine the rest of the time. I only have the problem at WOT. Any ideas?
