72 Panterta, In case youre interested!
LubeDude
Id really rather be fishing!<br /><br />So the Cluch problem is fixed. so on to other things!<br /><br />Checked the front suspension and found NO cotter pins anywhere, (NICE)!! Fixed that!!<br /><br />Then it overheats every time I get into town! I bring it into the shop and start checking everthing out! Fan comes on OK, Blead the cooling system, everything seems ok! I take it out and it overheats! Check everything again, take it out and it overheats in town! Bring back to the shop and pull the fan sending unit and test it in boiling water, Its fine, it comes on at 170! Oh, but wait, IT GOES OFF AT 180!! (NICE), glad I left it in the water a little longer!<br /><br />Cant get the updated sender unless you buy an aluminum radiator, $600.00 + $50.00 for new sender + Mounting kit $50.00! The original is LUCAS and isnt known to be very dependable I find out! So off to NAPA I go and find a sender that will work if I make an adapter! Then to the metal store to get a peice of 1/2" Aluminum to make the adapter! One hour later I have it made and the rest of the day putting everything back together! Just fired it up and it appears everything is ok! If the weather holds, Ill drive it tomorrow! <br /><br />I wonder what next??<br /><br />sorry, wrong forum!! Oh well!!
JB
Re: 72 Panterta, In case youre interested!
I'll move it for you, LD.
