75hp Merc stalls when shifting into gear
Diver_1
Hi:
I have a 1984 75hp mercury 4 cyl, put it in the lake and it started ok, but when I shift into either forward or reverse it quits.
If I use the button on the throttle lever to just use the throttle, it will idle, and throttle up ok, no hesitation whatsoever. But when I put it back to neutral, then put it in gear, it just quits. doesn't make sense to me that if the motor is running fine, then goes under a load for it to do that. I am obviously not understanding what is happening here.
This is my first Merc, I have a manual and am going thru it, just have not run into this problem before with my evinrude.
Before putting it in the water I did a compression check-all cylinders are at 150psi.
spark was good
just rebuilt fuel pump.
Any ideas,?? and thanks for your patience
hamit59
Re: 75hp Merc stalls when shifting into gear
Question have you checked the lower? Will it go into gear out of the water running on muffs. Have changed out the lower lube? If so was it milky, creamy or was there water in It?
Reply back with your findings
