Re: 78 Johnson 15 HP Fuel Problem
Tom:<br />Has your dealer put a vacuume gauge on this engine yet. This test should be able to narrow your problem. With what I have read here, Two things, <br />1) Try a new fuel pump.<br />2) is there a restriction in your pulse line, the vac***e test will show this. You should develop aprox 1 Lb of vac***e at idle, 2.5-4 LBs at mid to upper rpm's.<br />Good luck, Rob.QUOTE]Originally posted by Tom:<br />78 Johnson 15 hp. So far I have rebuilt fuel pump,rebuilt carb,replaced fuel lines on engine,replaced primer bulb and fuel line connectors from tank,replaced gasket on gas tank.It will start but runs itself out of fuel.It does not seem to be able to draw fuel from the tank.Ive done everything but replaced the fuel tank.Any suggestions would be appreciated. Thanks Tom[/quote]
