'84 Yam 115 HP V4 Model 115AETO - water pump
wilde1j
Helping a neighbor change a water pump. He has a Clymer manual which doesn't say much about the shift shaft. How does it disconnect (it looks like it may just separate somewhere in the middle without any specific action)???<br /><br />Everything else looks straightforward ... 7 bolts to drop the LU, whatever the shift shaft needs, and down and out. Correct?<br /><br />Don't want to start the project w/o knowing this detail.<br /><br />Advise please. Tkx.
wilde1j
Re: '84 Yam 115 HP V4 Model 115AETO - water pump
Anybody know these old Yam's????
vinney
Shift shaft is splined above the lower unit. Male female spline. Pull the lower unit in neutral. Remove the speedo hose too.
