87 Johnston 25hp keeps stalling
mcchris96
my motor will start run for a couple seconds and then stall, also sometimes when i am starting it, it will give a pop sound and a puff of smoke blows out of the exhaust. once I finally get it in gear and running it works great any ideas???
Cofe
Re: 87 Johnston 25hp keeps stalling
The symptoms that you listed, could be caused by several different engine disorders. Take a look at the secret file....http://forums.iboats.com/showthread.php?t=299680
Personally I would start with a carburetor kit. If that doesn't help then a fuel
pump kit. But it is hard to tell what is really going on, it may be some other problem.
Without getting my hands on this motor, it is hard to diagnose. It might be best to have it diagnosed by a marine mechanic. Then decide if you want to do the work yourself.
tashasdaddy
"it will give a pop sound and a puff of smoke blows out of the exhaust." tells me the flywheel woodruff key is sheared, and threw the timing off, pull flywheel and check.
