89 alpha 1 outdrive with gear oil in driveshaft bellows, seals changed 2 months ago
stang32
so i replaced the inner shaft seal about 2 months ago, the yoke didnt look scored, it cleaned up nice with emery cloth. i had to pull the drive this weekend because of engine issues and there is gear oil back in the driveshaft bellows again. i pulled the drain plugs and very little came out. i pressure tested the drive @ 15lbs for 2 hrs and rotated the shaft severl times and the pressure doesnt drop. very odd, right? any thoughts?
achris
More fish than mountain goat
Try the pressure test at 3 or 4psi... I've seen seals that hold at high pressure leak badly at low.
Chris....
alldodge
Also grab the yoke and try to move it up/down and side to side to see if this causes loss of pressure
harringtondav
??? If the gear yoke moves as above with the castle retainer fully torqued, there is a serious loss of preload in the drive gear's bearing set. Agree this could cause a leak, but it can also cause major problems with the gear set.
Also 15 psi is getting a little too high. If the Alpha I has the same seal carrier under the water pump as the Gen II, you run the risk of blowing it up out of it's bore. Been there myself, before I learned 10 psi is the recommended limit.
stang32
So i lowered the pressure to under 5psi and no change. Pressure holds. Ive spun the yoke numerous times. I guess im just going to tear it apart and hope i find an issue with the seal/yoke.
stang32
i tore the upper seal out today and there is a slight grove in the yoke, more visual than physical, in other words, i dont feel it with my finger nail, i changed the yoke anyway . its under pressure overnight with about 5psi
hope this solves my issues
NHGuy
I have heard of folks placing the seal at a depth that lands the wiper on fresh metal.
achris
40 thou deeper into the carrier than 'normal'... Works a treat...
Chris....
stang32
so the drive has held pressure at 5psi for 2 days, im pretty sure this will do the trick
