Ok so this was my fault and i'm having the fun of trying to understand how the elctrical system on this thing works. I pulled off the ignition switch to put on a new gauge cluster panel and clean the connections at the same time. Being in a rush I slipped with the screwdriver and popped the power wire, assumed oh well there's another fuse I will have to replace. After further inspection I also noticed that I wasn't getting any power up and down on the motor. I see that the ignition harness completely bypasses the fuse panel and goes directly to the engine. The only thing I'm seeing are the 2 40amp Hella relays. Where does it get all it's power from are there any fuses or is it just these 2 relays?
