Hello all. Can any one explain the best they can how the steering works on these? My engine is stuck. The wheel moves. It will nudge the engine than that's it. I have a rod that slips into a tube than the opposing side has a threaded nut. I removed that nut and moved the wheel and the inner rod came out? So I removed all the old grease applied new with a few shots of pneumatic oil. So how does that inner rod actually pull the engine back from the far right position? I will try to shoot some pictures and maybe even a video tomorrow. As I have run out of daylight today.
Thank you.
Frank
Pennsville NJ
Thank you.
Frank
Pennsville NJ
