I have a noise that only occurs under load. At 2.5k rpm it you can really here it. At idle there is no noise. Sounds like a bearing, its meadium in pitch, not high pitched at all. It varies with engine rpm. I am guessing a crank or rod bearing. The engine has close to 1000 hours on it. Just did a compression check: left bank,112-115-110, right bank,106-111-110. The engine runs fine, power is fine for its age. I plan to pull the manifold on sunday to check things out. What should I be looking for? I don't that much experience with outboards, at least with internal problems. Have lots or 4 cycle car engine experience. If it is a bearing I plan to just get a rebuilt power head, the engine is about at that point I believe. Any advice on where to get a GOOD rebuilt power head from? Any advise on what the problem might be and what I should do? Thanks.<br /><br /><br />Stacy
