ggundersen3
- Dec 25, 2007
- 249
The overheat alarm sounded twice a few weeks ago after slowing down to low RPM after running high RPM (2/3-3/4 throttle). I took it to local dealer and they said it was the water pump that was bad so I paid them to replace it and they stated they tested the motor afterwards and all was OK. This weekend I out on a local lake and it seemed fine until the same situation took place, I was running 3/4 throttle for quite some time, then finally slowed down to "no wake speed"and after running slow for 10 minutes, the overheat alarm sounded again! It happened twice on Saturday. Obviously the water pump wasn't causing this. What could it be causing this? This is exactly what it was doing before installing the new water pump. The new water pump made no difference. It's something else!
