1) Performance issue you are trying to correct.
Slow planing, but once it does the rpm will be a little high at wot.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
quicksilver 48-13704-23 non mirage
3) Current prop diameter and pitch (required).
23p 14 5/8 3 blade SS
4) Wide open throttle RPM and speed with an average load (very helpful)
trim full down 4800, trim in best plane position 5100 with good water condition. max speed 58mph.
5) Engine/drive make, model, year, and HP
454 Bravo 1 1988 330hp non mag motor max recommended rpm 4600-4800
6) Boat make model, year, length and weight
1988 Glastron gx 239 ultra 23ft weight is 3500 dry
Overall the performance it tolerable, I like the high top speeds, but would like it to plane a little better and would feel safer if the rpm didn't go over 4800. I was thinking of trying a 4 blade 24p, but I dont have experience in prop selection.
