Im having issues with my engine running well under load past 4k rpm. So im trying to rule out timing issues. It a 95 vortec 350 with an edelbrock intake and 750 cfm carter marine carb. Fuel pressure is 7 psi. I set initial timing at 12 degree and at 4000 rpm the timing advances to 26 degrees. Does my total timing seem low? I know the voyager has a flat timing curve and ideally id like to be around 30-32 degrees for this engine. Should i advance my idle timing to 18 degrees to get my total up to 30?
