Hi;
I have an '88 Chaparral w/ twin 350's (260) and Alpha 1 drives. I replaced the sea water pumps on both drives and the gimble bearing, U-Joint, and bellows on the portside. The starboard side drive slid right in and came within 1/2" of mating with the bell.
The portside drive feels like it mates w/ the coupler splines but positively stops about 1/2" before the studs on the bell are visible. The new u-joints look like they buckle and kink, giving me the impression that something isn't aligned correctly. I bought an alignment tool and it seems that my alignment is way out because the bar doesn't go in easily. With the shaft inserted as far as it will go (w/out forcing it), it appears to point to the right (not centered in the u-joint cavity) and it looks like I have less grease on the bottom as opposed to the top of the bar. Generaly speaking, how much should I mess w/ the adjustment bolts. For instance, will one full turn on each bolt move the front of the engine a bunch or fractionally? As always, I appreciate all the advice and help this forum provides.
Fred
Fred
