Alpha I outdrive woes
searay280
02 SeaRay 280DA w/T 4.3's and Alpha I outdrives. When trailering the boat yesterday the port side outdrive will only go down approx. 1/4 and then made a screeching noise and stopped. It will go up all the way with the trailer switch but again, only 1/4 way down. Any suggestions? Thanks!
achris
More fish than mountain goat
Re: Alpha I outdrive woes
The scraper seal in the ram end caps have leaked and allowed water into the outer section of the end cap and it's corroded and is clamping on the rod. The reason it will go up is because up pressure is about 3,000psi and down pressure is only about 700... You need to replace the end caps before you do any damage to the rods.
If you NEED to get the drive down, then have someone stand on it while you press the switch. Beware that you will run the risk of scratching the rod if you do that, and it will leak oil and water forever, even with new end caps.
Chris.............
Ayuh,...
Is there Oil in the reservoir,..?? Is it still Oil,..??
Edit,...
From total opposite ends of the earth, at the Same moment,....
What time is 8:13 eastcoast US where you are Chris,..??
Man,... Ya Gotta Love the internet,.....:D
Don S
And what are you doing in Norway? Thought you were headed to Malaysia
achris
Bondo,
It's currently 8.13 am on Tuesday... I'm actually on a boat 200 miles out to sea in the South China Sea, 7*10'N, 103*46'E, and it's the same time in Perth.....
Looks like you are exactly 12 hours behind me :D:D:D
Chris..............
Chris..............
Ayuh,....
And I doubt I'll Ever catch Up,...... ;)
achris
Hmmmm!!! Moderators rights again!!!
I am in Malaysia... You looked at my IP address and jumped to conclusions. Well, haha on you :D:D:D... The boat's internet access is routed through a Norwegian server....
And this is the boat!!! Care to be Chief Engineer?
attachment.php
Chris............
JustJason
what do ya do with that rig achris? Hope your not minesweeping!!
achris
I operate and maintain ROVs... Underwater robots. Used mainly in the oil and gas industry....
Chris...........
betayv
ufff hey how deep is the water there? I guess you dont get sea sick!!!
achris
is there good money in that?
I'm happy with it... :D:D:D:D
Currently working in 53 metres (170 feet), which is quite shallow for us. I prefer the deeper water, anything over 200 metres (650 feet). We are capable of operating up to about 3000 metres (10,000 feet). Deepest I've had a vehicle is 1400 metres (4,600 feet). It's dark down there :eek::eek:
Nope, don't suffer 'mal de mare'... Not good if you're at sea for 8, 9 weeks at a time....
Chris.........
FreeBeeTony
Gotta say that's pretty impressive..........
Not only what Chris does............but that Don knew where hes was(n't)........
