turtle1173
- Nov 29, 2001
- 437
This 1972 Chrysler 85HP had a blown head gasket when I got it (of course I didn't know it when I bought it). I replaced the head gasket and have been working on it for the past couple months. Today I finally got it to run in gear but it didn't have much power and was blowing white smoke. Upon pulling the plugs, it was clear that some water was getting into the #1 cylinder. I pulled the head and the gasket was blown. This occured with about 15 minutes of "in gear" running.<br /><br /> I want to know if this would be caused by some restriction in the cooling circuit or something else. My manual talks about a water pressure release valve that, if stuck, would put excessive pressure on the system and would come through at the weakest point. Do you think this is a possiblity?<br /><br /> I hate to even think about this but do you think I need to take the exhaust manifold apart and check these passages?<br /><br />Thanks,<br /><br />Shane
