Aq145a
Barrynv
Can anyone please help I am getting water in my oil in the engine The sealed cooling water is not going down can it be coming from the exhaust manifold on removing the manifold and connecting a hose to the oil cooler outlet water comes out of no1 and 4 ports on the manifold is this normal the manifold is brand new
alldodge
The oil cooler has a lot higher pressure on the oil side then the water. If it was leaking oil would start reducing and run very low real quick.
Your exhaust manifold is probably leaking water into the cylinders. Check the spark plugs and if they are white and clean then they are being steam cleaned
