Woodonglass
- Dec 29, 2009
- 25,930
If you feather both sides of of the edges 5-6 inches, On the boat and on the new glass, and then use mulitiple layers of resin and glass, then yes it will be strong.
Anyone have advice as how to pour the foam under the deck that contains the rod tubes? Just estimate and pour it all at once, or smaller batches? The result I want is total encapsulation of the pvc tubes without voids, or as minimum as possible
Really looking forward to seeing your finished boat!Lower unit installed, boat splashed. Now time to make it look good. Im researching what color metal flake to paint trying to decide. What is the easiest body filler to use to do the fairing? Peanut butter? Ive seen some people mix bondo with resin for easier sanding.
I see you were using the same tool I did when I installed a new transom on one of my old boats. Just can't beat what you have on hand. Who knew an old tire iron could be so handy... LOLGot my resin today from a place that does boat repairs for $22 a gallon pretty excited about that. Ordered my fabric should be in by next Thursday so that gives me a week to prep, should get there.
Some updates, almost all out:
