gm280
- Jun 26, 2011
- 14,605
I've searched and searched some more on here and while I have found bits and pieces on live wells, there just isn't one thread, that I have found anyways, devoted to building a basic live well. So here goes such a thread. And if this is in the wrong forum, please move it to the appropriate place...there will be no hard feelings on my part.
As I approach building my new live well for my 14' tri-hull fishing boat refurbishing project, I wrestle with building it big, but not too big, to suit my needs. But honestly I really don't know what size to go with. I want a nice size, but don't want to carry around lots of water weight as well. So there is a fine balance between the two needs. My idea is to use a new, or even an old, cooler for the basic design and then build a shell around it to install it permanently in the floor of my boat project. I know how to plumb it and have already built the aerator circuitry to cycle fresh water through it when there are fish in it. But the actual size is still up in the air. I have been looking at 48 quart coolers and wonder if that is too small or what. And whatever size I go with, I will build a custom plywood shell around it and even use rigid closed cell foam sheets from the Lowes type stores to help with insulating it to keep the fish cooler and alive. Of course that shell will be polyed and CSM/1708 in place as well. Then the top will be hinged and customized with matching vinyl to match the seat so everything looks uniformed. But what should an adequate size be? Any suggestions as to building and/or plumbing and size would certainly make this a total go too thread for future searchers. Oh and this build is for fresh water and not some huge deep sea fishing capability. And I do understand that any cooler I chose will not be filled to the top, but merely about 2/3 of the way set be the stand pipe or overflow outlet. So bring on your best ideas and building designs...
