My boat has started to make a beeping noise and hopefully someone can lend some tips.
It is a 97 Hurricane Deck boat with an Evinrude 90 motor. The beeps are a few seconds apart. I tried timing them but they are not consistant but mainly a few seconds apart. It sounds as if coming from around throttle area but I assume that is just where the alarm is located.
Also, it doesn't start beeping right away. I can run it for a few a minutes before it starts to beep.
Any thoughts on what this may be and how to check for a resolution?
Thanks
James
Thanks
James
