gm280
- Jun 26, 2011
- 14,605
Re: Boat shop says I need a rebuild, not sure to beleive them.
Actually the fuel mix fills in the two stroke engine both from vacuum AND pressure, but from different sections. As the piston goes down in the cylinder to release the burnt exhaust gases at the exhaust ports, pressure is built in the crankcase closing the reed valves for that cylinder section to force the mix into the cylinder as soon as the piston gets to the intake port openings. But as it does get to those intake port openings it continues traveling downward creating a vacuum to help pull in the fuel mix from both the downward travel of the piston but also the vacuum the exhaust gases create leaving the cylinder too. I don't know where the lower compression limit actually is for a good running OB...? I'd run it if it were me... JMHO! :joyous:
