I bought this boat used and replaced the bunks shortly after I got the boat. I basically have the bunks in the same location as the old bunks however I did lengthen them to reach all the way to the transom. As you can see from the pictures, the bucks are laying with the 6" side against the hull. I have seen a lot of boats with a 4x6 with the 4" part against the hull, which would give more support to the transom then the setup I have. I have read about the hull bending when it is supported like mine is and it does look like I have a bend in my hull. So I am thinking about changing to a 4x6 and letting it extend a few inches past the transom. The boat is a action craft 1720 with a 115 4stroke mercury. My questions are, should I be concerned with how the bunks are now? If I change to the 4x6 where should they be placed with reference to the hull? As you can see the transom is hanging over about 15" from the bunk support.
