Cam specs.
magster65
This kinda' goes with Albe's questions. I understand the engines have a much different task but what are the spec. differences between a marine cam and an automotive grind? Let's use the 5.7 GM for example.(?)
Re: Cam specs.
I think you'll find that,<br /><br />Truck cam profiles,<br /><br />RV cam profiles,<br /><br />And marine cam profiles,<br /><br /> are pretty much the Same..... Max power from idle to 5000rpms....
