Re: can a prop wear out?
That should fix your problem.If the prop is beat up you will probably notice a big increase in performance with a new prop. Your best bet is to replace the prop and hub assembly like you said.<br /><br />Keep the old prop for a spare to get you back to the dock if something like this happens again.If you can afford it, buy a extra hub assembly and keep it with the spare prop.
