Re: carb rebuild?
If that carb hasn't been touched in 13 years, I would think it's definitely time to go through it.
The rebuild kits come with good instructions (for the most part).
You just have to ensure that you get the right marine kit, and make sure it's from Holley, and not Sierra, etc...
Also make sure you get the one with the exact same diaphram pump, and power valve.
The right kit will contain all new gaskets, and even extras that you don't need. Pay special attention to those gaskets, as there are some very tiny ports cut out that are critical if you block them off w/ the wrong gasket. Just lay old over new to see which ones you will need, and which to set aside, and which way they actually go on the part....some are not reversible.
I would carefully note the location of the float before removing the needle/seat for replacement.
Holley's definition for a "center hung" and "parallel to the bowl" float leaves a lot of wiggle room for interpretation, especially when there are four or five flat surfaces on the float, and calling their help line was less than.......helpful.
But overall the rebuild is pretty easy. Just take pic's with your phone during each step in case you have a "where did that go?" moment during re-assembly.
