tommays
- Jul 4, 2004
- 6,768
Shift Shaft Assembly <br />REMOVAL <br />NOTE: It is possible to remove and service the shift shaft assembly (but not the shift crank <br />inside the gear case) without removing any of the internal components of the gear housing. <br />1. Remove the shift shaft bushing screws and remove the shift shaft by pulling it straight <br />out of gear housing. <br /><br /><br />on page 3B-47 it says you can slip it out without takeing apart the gear box <br /><br />and kind of leaves you hanging <br /><br />just wondering if the shift crank is likely to fall out of position while changeing the seal ? or its as simple in real life as the manual says<br /><br />tommays
