andrew j cox
- Feb 11, 2015
- 149
Ive been ferreting away on my 115 Im playing with the cooling system, it had no thermostat and the poppet valve was corroded stuck, I drilled the valve out, when I put the hose to the thermostat should I get water out the bypass hole? Only getting a trickle out the mid section outlet, I really don’t want to pull the head off but what if it’s caked up with crud, engine was used in the sea most it’s life doubt they were overly careful about flushing it, maybe I should drop the head.
